Effective December 3 - NetApp adopts Microsoft’s Business-to-Customer (B2C) identity management to simplify and provide secure access to NetApp resources. For accounts that did not pre-register (prior to Dec 3) access to your NetApp data may take up to 1 hour as your legacy NSS ID is synchronized to the new B2C identity. To learn more, Read the FAQ and Watch the video.
NetApp Knowledge Base
Unknown length error counts up
164
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
Issue
  • "ifstat -a" counts up length errors, but there are no warnings or notifications from ONTAP.
Example:
-- interface  e0d  (248 days, 3 hours, 37 minutes, 44 seconds) --
RECEIVE
 Total frames:    57430k | Frames/second:       3  | Total bytes:      7183m
 Bytes/second:      335  | Total errors:       15  | Errors/minute:       0
 Total discards:      0  | Discards/minute:     0  | Multi/broadcast: 57145k
 Non-primary u/c:     0  | CRC errors:          0  | Runt frames:         0
 Fragment:            0  | Long frames:         0  | Jabber:              0
 Length errors:      15  | No buffer:           0  | Xon:                 0
 Xoff:                0  | Pause:               0  | Jumbo:               0
 Noproto:             0  | Error symbol:        0  | Illegal symbol:      0
 Bus overruns:        0  | Queue drops:         0  | LRO segments:       95
 LRO bytes:       34067  | LRO6 segments:       0  | LRO6 bytes:          0
 Bad UDP cksum:       0  | Bad UDP6 cksum:      0  | Bad TCP cksum:       0
 Bad TCP6 cksum:      0  | Mcast v6 solicit:  151
TRANSMIT
 Total frames:      285k | Frames/second:       0  | Total bytes:     18264k
 Bytes/second:        1  | Total errors:        0  | Errors/minute:       0
 Total discards:      0  | Queue overflow:      0  | Multi/broadcast:     0
 Xon:                 0  | Xoff:                0  | Pause:               0
 Jumbo:               0  | Cfg Up to Downs:     0  | TSO non-TCP drop:    0
 Split hdr drop:      0  | Timeout:             0  | TSO segments:        0
 TSO bytes:           0  | TSO6 segments:       0  | TSO6 bytes:          0
 HW UDP cksums:       0  | HW UDP6 cksums:      0  | HW TCP cksums:      96
 HW TCP6 cksums:      0  | Mcast v6 solicit:    0
DEVICE
 Mcast addresses:     1  | Rx MBuf Sz:       4096
LINK INFO
 Speed:            1000M | Duplex:            full | Flowcontr
  • The following error is confirmed only once from the EMS log.
Example:
Tue Feb 16 15:59:45 JST [node-2: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e0d on node node-2 is reporting a high number of observed hardware errors, possibly CRC errors.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
