Unexpected node reboot with 'Power on Reset(Normal Power Cycle)' event
Applies to
- AFF systems
- FAS systems
- Service Processor (SP)
- Baseboard Management Controller (BMC)
Issue
- Unexpected node reboot
- SP or BMC raise "
Power Reset
" event:
[IPMI.notice]: 9200 | c0 | OEM: ffff7000ff00 | ManufId: 150300 | SP Power Reset
[IPMI.notice]: 9300 | c0 | OEM: fcff70560000 | ManufId: 150300 | POS Register: Power on Reset(Normal Power Cycle)
or
[IPMI.notice]: 00d4 | c0 | OEM: ffff7000ff00 | ManufId: 150300 | BMC Power Reset
[IPMI.notice]: 00d5 | c0 | OEM: fcff70560000 | ManufId: 150300 | POS Register: Power on Reset(Normal Power Cycle)
- Partner takeover due to missed heartbeat
[node_name: cf_main: cf.fsm.takeover.noHeartbeat:alert]: Failover monitor: Takeover initiated after no heartbeat was detected from the partner node.
- No other suspicious error messages.
- The node works fine after the giveback
