NetApp Knowledge Base
Unable to reserve disks on source node
103
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2522
  • ONTAP 9.7P14
  • Advance Disk Partitioning (ADP) v1
Issue
  • Continuous event in the EMS-LOG-FILE section of AutoSupport
    raid.disk.replace.job.failed: Failed to replace disk 2.1.1 with disk 2.2.1. Reason: Reserve: Unable to reserve disks on source
    node Node-02
  • Issue is only seen on one node
  • In " ::> run -node <node_name | local> -command sysconfig -r
    • Disk 2.2.1 is a smaller disk than disk 2.1.1
    • Disk 2.1.1 is not broken or failed
    • There is no reason to replace the disk
  • There was no command executed to replace the disk
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
