NetApp Knowledge Base
The status of e0M not changes even remove or connect network cable
263
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • AFF-A400
  • FAS 8300
  • ONTAP9.7P1
Issue
  • When e0M is up status, remove the network cable can't change the status from "up" to "down".
  • Conversely, if there no cable is attached to e0M port and the port status is "down", after connecting cable , the port status remains "down" and will not change to "up" indefinitely.
  • Node management access can be affected because LIF failover does not occur.
New to NetApp?
Scan to view the article on your device
