NetApp Knowledge Base
The old system ID is displayed because the controller is replaced during partial giveback
985
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2750
  • ONTAP 9
Issue
  • The e0b on node2 go down, so replacing the network cable, but cannot link up.
 Example of EMS snip:
<LR d="13Oct2020 10:29:18" n="node1" t="1602552558" id="1597219663/56726"
p="6" s="Ok" o="kernel" vf="" type="0" seq="732963" >
<netif_linkDown_1
       lanType="Ethernet"
        ifName="e0b"
        status="down, check cable"/>
</LR>
<LR d="13Oct2020 10:29:21" n="node1" t="1602552561" id="0/27191437951018"
p="5" s="Ok" o="vifmgr" vf="" type="1" seq="732964" >
<vifmgr_portdown_1
 nodename="node1"
        portname="e0b"/>
</LR>
<LR d="13Oct2020 10:29:22" n="node1" t="1602552562" id="0/27191437951019"
p="5" s="Ok" o="vifmgr" vf="" type="1" seq="732965" supp="1" >
<vifmgr_lifmoved_linkdown_1
        vifname="vif2"
 vsrvid="4294
967293"
        vifip="XXX.XXX.XX.XXX"
        tonode="node1"
        toport="e0a"/>
</LR>
  • Therefore, replacing the controller of node2, both e0a/e0b went down.
  • The node2 controller is replaced, but the new controller is DOA, so return original controller after checking "storage failover show" status.
Example of sysconfig -a snip:
        slot 0: 10 Gigabit Ethernet Controller IX5-SFP+
                e0a MAC Address:    XX:XX:XX:XX:XX:XX (auto-unknown-fd-down)
                e0b MAC Address:    XX:XX:XX:XX:XX:XX (auto-unknown-fd-down)
    Device Type:        X550EM
                Firmware Version:   0.86
down)
                Device Type:        X550EM
     Firmware Version:   0.86-7.1
cluster1::> storage failover show
                              Takeover
Node Partner        Possible State Description
node1      node2          true     System ID changed on partner (Old:
                                       XXXXX
5509, New: 538110616),
                                       Connected to node2, Partial giveback
node2          node1          -       Waiting for cluster applications to
                                       come online on the local node
                   Offline applications: mgmt, vldb,
                                       vifmgr, bcomd, crs.
2 entries were displayed.
  • Replacing the controller on node2 again, the e0a/e0b link are restored, but the remain old system ID(CCCCCCCCC) before the replacement.
  • So "disk reassign" from the maintenance mode of node2, but couldn't change some of disks.
Example of console log snip after disk reassign:
*> disk reassign -s CCCCCCCCC -d AAAAAAAAA -p BBBBBBBBB
*> disk show -v
Local System ID: AAAAAAAAA
  DISK       OWNER                    POOL   SERIAL NUMBER         HOME                     DR HOME                CHKSUM
Oct 25 09:35:48 [node2:diskown.duplicateSoftEntries:notice]: Found duplicate filer_table entries with same name node2 but different system ids ( CCCCCCCCC, AAAAAAAAA )
0b.00.21     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.21P1   node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.21P2   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.8      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.8P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node2     (CCCCCCCCC)                          Block
0b.00.8P2    node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.7      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.7P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.7P2    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.1      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.1P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.1P2    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node1     (BBBBBBBBB)                          Block
0b.00.23     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.23P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.23P2   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.15     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.15P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.15P2   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node1     (BBBBBBBBB)                          Block
0b.00.4      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.4P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node2     (CCCCCCCCC)                          Block
0b.00.4P2    node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.14     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.14P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node2     (CCCCCCCCC)                          Block
0b.00.14P2   node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.12     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.12P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node2     (CCCCCCCCC)                          Block
0b.00.12P2   node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.18     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.18P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node2     (CCCCCCCCC)                          Block
0b.00.18P2   node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXXX    node2     (AAAAAAAAA)                          Block
0b.00.16     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.16P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node2     (CCCCCCCCC)                          Block
0b.00.16P2   node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.3      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXX        node1     (BBBBBBBBB)                          Block
0b.00.3P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node1     (BBBBBBBBB)                          Block
0b.00.3P2    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.20     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.20P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node1     (BBBBBBBBB)                          Block
0b.00.20P2   node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXXX    node2     (AAAAAAAAA)                          Block
0b.00.10     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.10P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node2     (CCCCCCCCC)                          Block
0b.00.10P2   node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.0      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.0P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXXX   node2     (CCCCCCCCC)                          Block
0b.00.0P2    node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.5      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXX        node1     (BBBBBBBBB)                          Block
0b.00.5P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.5P2    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node1     (BBBBBBBBB)                          Block
0b.00.13     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXX        node1     (BBBBBBBBB)                          Block
0b.00.13P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node1     (BBBBBBBBB)                          Block
0b.00.13P2   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.19     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.19P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.19P2   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.17     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.17P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node1     (BBBBBBBBB)                          Block
0b.00.17P2   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.11     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.11P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXXX   node1     (BBBBBBBBB)                          Block
0b.00.11P2   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXX    node1     (BBBBBBBBB)                          Block
0b.00.6      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.6P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node2     (CCCCCCCCC)                          Block
0b.00.6P2    node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXX     node2     (AAAAAAAAA)                          Block
0b.00.2      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.2P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXXXX   node2     (CCCCCCCCC)                          Block
0b.00.2P2    node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXXX    node2     (AAAAAAAAA)                          Block
0b.00.22     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.00.22P1   node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node2     (CCCCCCCCC)                          Block
0b.00.22P2   node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXXXXXXXX    node2     (AAAAAAAAA)                          Block
0b.00.9      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXX         node1     (BBBBBBBBB)                          Block
0b.00.9P1    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0b.00.9P2    node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXXXXXXX     node1     (BBBBBBBBB)                          Block
0a.10.11     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.9      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.19     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.23     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.17     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.5      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.22     node2     (AAAAAAAAA)    Pool0  XXXXXXXX              node2     (AAAAAAAAA)                          Block
0a.10.7      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.15     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.1      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.3      node1     (BBBBBBBBB)    Pool0  XXXXXXXX   X          node1     (BBBBBBBBB)                          Block
0a.10.21     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0a.10.13     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node1     (BBBBBBBBB)                          Block
0b.12.5      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.12.10     node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXX          node2     (AAAAAAAAA)                          Block
0a.11.10     node2     (AAAAAAAAA)    Pool0  XXXXXXXXXXXX          node2     (AAAAAAAAA)                          Block
0a.11.9      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.12.7      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.12.11     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.12.9      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0a.10.18     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.0      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.4      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.2      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.10     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.12     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.16     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.8      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.14     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.6      node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.10.20     node1     (BBBBBBBBB)    Pool0  XXXXXXXX              node2     (CCCCCCCCC)                          Block
0a.11.5      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.12.3      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0a.11.3      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0a.11.11     node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0a.11.7      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0a.11.1      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0b.12.1      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node1     (BBBBBBBBB)                          Block
0a.11.8      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0a.11.4      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0a.11.2      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0b.12.2      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0b.12.6      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0b.12.4      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0b.12.8      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0a.11.6      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0a.11.0      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
0b.12.0      node1     (BBBBBBBBB)    Pool0  XXXXXXXXXXXX          node2     (CCCCCCCCC)                          Block
  • After booting the system, the partial giveback is cleared, but another displayed.
Example:
                              Takeover
node1         node2          true     Connected to node2. Node owns aggregates belonging to another node
                                       in the cluster.
node2          node1          true     Connected to node1
New to NetApp?
