NetApp Knowledge Base
System with the fix of Bug 1073579 still reports the warning message 'The NVRAM battery current is below normal (-50 mA)'
981
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS9000/AFF-A700
  • NVRAM10 FPGA 1.2.0 and above
Issue
The system is running a fixed version for Bug 1073579. But still seeing the same symptoms.
  • FPGA version can be find in the "sysconfig -a" command via console, or examining " SYSCONFIG-A " in ASUP:
Example:
slot 6: NVRAM (NVRAM 10)
Revision:           B0
Serial Number:      031945002448
DIMM Size:          16384 MB
Memory Size:        32768 MB
Battery Status:     Battery sufficiently charged
Running Firmware:   1.2.0
  • The 'current is below normal (-50 mA)' warning message is followed by a 'current is normal' message within a minute in the EMS logs:
Example:
3/24/2020 21:19:58  node-04    ERROR        nvram.battery.current.low.warn: The NVRAM battery current is below normal (-50 mA). To prevent data loss, the system will shut down in 24 hours.
3/24/2020 21:20:39  node-04 INFORMATIONAL nvram.battery.current.normal: The NVRAM battery current is normal.
3/24/2020 21:20:58  node-04 ALERT        callhome.battery.warning: Call home for BATTERY (current low) WARNING.
  •  The Service Processor (SP) system event log displays the following information:
Example:
Record 790: Tue Mar 24 12:19:56.369380 2020 [IPMI.notice]: 7b02 | 02 | EVT: 0150ffff | Bat_Curr | Assertion Event, "Lower Non-critical going low " | Reading: -0.050 | Threshold: -0.050
Record 791: Tue Mar 24 12:19:58.174179 2020 [IPMI.notice]: 7c02 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
Record 792: Tue Mar 24 12:20:27.937336 2020 [IPMI.notice]: 7d02 | 02 | EVT: 6f02ffff | PCM_Status | Assertion Event, "Fault"
Record 793: Tue Mar 24 12:20:32.217038 2020 [IPMI.notice]: 7e02 | 02 | EVT: 6f02ffff | Bat_Status | Assertion Event, "Fault"
Record 794: Tue Mar 24 12:20:32.465387 2020 [IPMI.notice]: 7f02 | 02 | EVT: 815000ff | Bat_Curr | Deassertion Event, "Lower Non-critical going low " | Reading: 0.000 | Threshold: -0.050
Record 795: Tue Mar 24 12:20:39.985458 2020 [IPMI.notice]: 8002 | 02 | EVT: ef02ffff | PCM_Status | Deassertion Event, "Fault"
Record 796: Tue Mar 24 12:20:44.005772 2020 [IPMI.notice]: 8102 | 02 | EVT: ef02ffff | Bat_Status | Deassertion Event, "Fault"
Record 797: Tue Mar 24 12:20:45.997384 2020 [IPMI.notice]: 8202 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted"
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • Was this article helpful?
