System is in mixed path due to fault seen on SAS HBA
Applies to
- NetApp AFF and FAS systems
- Data ONTAP 8 7-Mode
- Clustered Data ONTAP 8
- Clustered Data ONTAP 9
Issue
Drives are missing a path to the node due to a faulty port on a SAS card
Shelf stack is not seen through IO Module A/B and drives connected through IO Modules A/B are not seen by the Node, refer to the additional information section
