Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
System fault LED light on and "Overcurrent Protection Fault"
757
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2750
  • Baseboard Management Controller (BMC)11.3P2
Issue
  • Storage fault LED is on.
  • Overcurrent Protection Fault error event can be found in the following command output.
Example:
::> system controller service-event show
Node             ID  Event Location                      Event Description
Clusternode-01
                 1   10G Port 1 in Controller A          Overcurrent Protection Fault
  • SP SHELF FAULT RQSTD error event can be found in the following command output.
Example:
::> system node run -node * storage show fault -v
Enclosure Status: normal
Channel: 0a
Shelf: 0
Shelf Type: DS224-12
Product Serial Number: xxxxxxxxxxxxxxx
Module Type: IOM12E
Vendor Unique Element 88-IOM12E: (PCM)
Element Status         Status Bytes  Status Descriptions
  1: OK                01,01,80,00   SP SHELF FAULT RQSTD
  2: OK                01,01,00,00
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
