System boot-up fails up with "WARNING: 0 disks found" error after motherboard replacement
Applies to
- Motherboard replacement
- This includes hardware refresh
Issue
- System fails to boot up and restarts repeatedly with the following error:
WARNING: 0 disks found!
Storage Adapters found:
0 Fibre Channel Storage Adapters found!
2 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Target Adapters found:
0 Fibre Channel Target Adapters found!
2 iSCSI Target Adapters found!
1 Unknown Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
Jan 15 18:49:54 [localhost:cf.fm.noMBDisksOrIc:warning]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
No root volume found.
Jan 15 18:49:55 [localhost:zapi.sf.up.ready:info]: ZAPI: system node stable after startup.
Rebooting... (press ctrl-c during boot to break reboot loop)
Uptime: 1m17s
System rebooting...
- Old motherboard is still the disk owner even after completing the motherboard replacement procedure.
*> disk show -v
Local System ID: 333333333
DISK OWNER POOL SERIAL NUMBER HOME DR HOME CHKSUM
0a.00.8 node-1 (111111111) Pool0 Y5bxxxxxxxxx node-1 (111111111) Block
0b.00.11 node-1 (111111111) Pool0 Y5cxxxxxxxxx node-1 (111111111) Block
0a.00.10 node-1 (111111111) Pool0 Y5dxxxxxxxxx node-1 (111111111) Block
0b.00.3 node-1 (111111111) Pool0 Y5exxxxxxxxx node-1 (111111111) Block
0b.00.9 node-1 (111111111) Pool0 Y5fxxxxxxxxx node-1 (111111111) Block
0b.00.5 node-1 (111111111) Pool0 Y5gxxxxxxxxx node-1 (111111111) Block
