NetApp Knowledge Base
System boot-up fails up with "WARNING: 0 disks found" error after motherboard replacement
198
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS systems
  • AFF systems
Issue
  • System fails to boot up and restarts repeatedly with the following error:
WARNING: 0 disks found!
Storage Adapters found:
0 Fibre Channel Storage Adapters found!
2 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Target Adapters found:
0 Fibre Channel Target Adapters found!
2 iSCSI Target Adapters found!
1 Unknown Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
Jan 15 18:49:54 [localhost:cf.fm.noMBDisksOrIc:warning]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
No root volume found.
Jan 15 18:49:55 [localhost:zapi.sf.up.ready:info]: ZAPI: system node stable after startup.
Rebooting... (press ctrl-c during boot to break reboot loop)
Uptime: 1m17s
System rebooting...
  • Old motherboard is still the disk owner even after completing the motherboard replacement procedure.
*> disk show  -v
Local System ID: 333333333
  DISK       OWNER                    POOL   SERIAL NUMBER         HOME                     DR HOME                CHKSUM
0a.00.8      node-1  (111111111)    Pool0  Y5bxxxxxxxxx          node-1  (111111111)                          Block
0b.00.11     node-1  (111111111)    Pool0  Y5cxxxxxxxxx          node-1  (111111111)                          Block
0a.00.10     node-1  (111111111)    Pool0  Y5dxxxxxxxxx          node-1  (111111111)                          Block
0b.00.3      node-1  (111111111)    Pool0  Y5exxxxxxxxx          node-1  (111111111)                          Block
0b.00.9      node-1  (111111111)    Pool0  Y5fxxxxxxxxx          node-1  (111111111)                          Block
0b.00.5      node-1  (111111111)    Pool0  Y5gxxxxxxxxx          node-1  (111111111)                          Block
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
