NetApp Knowledgebase
System Manager upload fails error "File not uploaded." File may exceeds the max size of 2048M or there is insufficient space."
415
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • OnCommand System Manager
  • ONTAP System Manager 9.6
Issue
Uploading a file through System Manager for an Ontap upgrade fails with the following errors:
00000015.005d2f07 165b2eab Thu Jan 30 2020 18:40:01 +01:00 [kern_sysmgr:error:12926] 10.10.10.10 |admin|ERROR|1580405910946|
Thu Jan 30 2020,18:39:51.84 Image upload from local failed and reason is :File not uploaded. This might be because file
exceeds the maximum allowed size of 2048M or there is insufficient space
This could be due to:
  1. Insufficient space in the root volume for each node (rarely occurs if following the Min Root size per HWU)
  2. File being uploaded is larger than the limit.
  3. Burt # 1186703 " Local image upload fails if cluster management LIF is not on home node "
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
