NetApp Knowledge Base
SP wrongly links up with 100Mbps even though the actual speed is 1Gbps
228
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • Service Porcessor (SP)
  • FAS8300
Issue
SP speed displays 100mb instead of 1gb.
Example:
NODE::> node run -node NODENAME sysconfig -a
        NetApp Release 9.7P3: Fri Apr 17 10:40:14 EDT 2020
        System ID: xxxxxxxxxx (node1); partner ID: xxxxxxxxxx (node2)
        System Serial Number: xxxxxxxxxx (node1)
        System Rev: B1
        System Storage Configuration: Multi-Path HA
        System ACP Connectivity: Inband Active
        All-Flash Optimized: false
        Capacity Optimized: false
        All SAN Array: false
        Backplane Part Number: 111-04200
        Backplane Rev: B0
        Backplane Serial Number: xxxxxxxxxx
        Service Processor           Status: Online
                Firmware Version:   13.2
                Mgmt MAC Address:   xx:xx:xx:xx:xx:xx
                Ethernet Link:      up, 100Mbps   <<<<<<< 1Gbps is normal
                Using DHCP:         no
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
