SP update fails on FAS80XX
Applies to
- FAS8040
- FAS8060
- ONTAP 9.8P5
- ONTAP 9.8P11
Issue
- Automatic SP update fails on FAS80XX platform
MGWD log shows
[kern_servprocd:info:5757] 0x80a408c00: 0: ERR: Servprocd::FTM: transfer_file: Failed to delete partially transfered /tmp/sp_image.tar.gz file.
[kern_servprocd:info:5757] 0x80a408c00: 0: ERR: Servprocd::SpUpdate: transferImage: FTM sp_send_file failed to transfer /mroot/etc/RLM_FW/sp_image.tar.gz to SP. Error 26. Sleep for 30 secs and retry. Retry count : 1
[kern_servprocd:info:5757] 0x80a408c00: 0: NOTICE: Servprocd::SpUpdate: transferImage: sending /mroot/etc/RLM_FW/sp_image.tar.gz to SP, destination: /tmp/sp_image.tar.gz.
[kern_servprocd:info:5757] 0x80a408c00: 0: ERR: Servprocd::FTM: transfer_file: failed transferring /mroot/etc/RLM_FW/sp_image.tar.gz to sp://Node-01:/tmp/sp_image.tar.gz. err:Executing: program /usr/bin/ssh host 10.229.76.71, user alpha552154, command scp -v -t /tmp/sp_image.tar.gz
- Trying to manually run the SP update command from cluster fails
- Ping from the node management LIF to SP fails
