NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
SP information is not displayed correctly
412
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
FAS2650
Issue
  • SP health shows degraded.
Node03::> system health subsystem show
Subsystem Health
SAS-connect ok
Environment ok
Memory ok
Service-Processor degraded
Node03::> system health alert show
Node: Node03-02
Resource: SP Config
Severity: Major
Indication Time: Tue Jan 19 09:21:38 2021
Suppress: false
Acknowledge: false
Probable Cause: Service Processor in node Node03-02 has no network
                connectivity.The cable between the Wrench port on the
                controller and the ethernet switch is disconnected.
Possible Effect: You might not be able to use the Service Processor to
                 remotely access, monitor, and troubleshoot your
                 storage system.
Corrective Actions: 1. Check the connection between the Wrench port and the ethernet switch.
                    2. If the cable is properly connected, ensure that the Service Processor's ethernet interface is configured properly by executing the command "system service-processor network show".
                    3. Check for network cable related issues.
                    4. Contact the technical support if the alert persists.
  • Node Node03-02's information can't be displayed.
Node03::> system service-processor show
IP Firmware
Node Type Status Configured Version IP Address
Node03-01 SP online true 5.1P1 XXX.XXX.XXX.XXX
Error: show failed: RPC: Unable to send
Node03::> system service-processor network show
Address
Node Status Family Link State IP Address
Node03-01 online IPv4 up XXX.XXX.XXX.XXX
DHCP: none
MAC Address: XX:XX:XX:XX:XX:XX
Network Gateway: XXX.XXX.XXX.XXX
Network Mask (IPv4 only): XXX.XXX.XXX.XXX
Prefix Length (IPv6 only): -
IPv6 RA Enabled: -
Subnet Name: -
SP Network Setup Status: succeeded
2 entries were displayed.
  • But the Attention LED is off and SP status is online in sysconfig -a.
Node03::> node run -node * sysconfig -a
Node: Node03-02
NetApp Release 9.1P11: Thu Dec 21 02:32:26 PST 2017
Service Processor Status: Online
Firmware Version: 5.1P1
Mgmt MAC Address: XX:XX:XX:XX:XX:XX
Ethernet Link: up, full duplex, auto-neg complete
Using DHCP: no
IPv4 configuration:
IP Address: XXX.XXX.XXX.XXX
Netmask: XXX.XXX.XXX.XXX
IPv6 configuration: Disabled
  • The issue can't be fixed by rebooting SP.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
