NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
SP inaccessible with e0M up and functioning
95
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS 8020
Issue
  • The Service Processor IP address is inaccessible on one node of the HA pair, the network connectivity was verified but the SP IP does not respond to pings.
  • The Cluster management and node management LIFs on the affected node, hosted on the e0M port, are functioning normally as they are pingable and accessible.
  • The MAC address for the Service Processor is not seen on the connected switch port, although the MAC addresses for the e0M port is seen.
  • The Service Processor was rebooted, and the firmware was attempted to be upgraded, which failed:
::> system service-processor reboot-sp -node <node name>
  • Service Processor upgrade failure (SP-MGMT-MLOG-TXT.GZ in Autosupport):
Jan 13 22:44:34 +0000 [node01: servprocd: sp.servprocd.upd.unexpt.evts:debug]: params: {'reason': 'Unable to transfer SP firmware image using network interface'}
[?] Thu Jan 13 22:44:34 +0000 [node01: servprocd: sp.servprocd.upd.error:error]: SP update error: SP firmware update failure has been detected.
[?] Thu Jan 13 22:45:00 +0000 [node01: nphmd: hm.alert.raised:alert]: Alert Id = SPAutoUpgradeFailedMajorAlert , Alerting Resource = SP Upgrade raised by monitor controller
[?] Thu Jan 13 22:46:22 +0000 [node01: servprocd: sp.servprocd.upd.evts:debug]: params: {'reason': 'SP Firmware network update from 3.10 to 3.11 has been triggered.'}
[?] Thu Jan 13 22:46:34 +0000 [node01: notifyd: callhome.ondemand.invoke.all:notice]: params: {'aod_req_id': '61e0a0969f3f553997c0cd32', 'sequence': '472', 'URI': '', 'subject': 'ON DEMAND (ALL:AODS TRIGGERED)'}
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
