NetApp Knowledge Base
SP firmware autoupdate failure in FAS80x0
83
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS 80x0
  • Service Processor (SP)
Issue
  • SP firmware autoupdate fails
  • Manual SP firmware upgrade from the cluster fails
  • The SP MGMT Logs will show the below indication
[kern_servprocd:info:6583] 0x80905cb00: 0: ERR: Servprocd::FTM: transfer_file: failed transferring /mroot/etc/sp_ssh_algo.conf to sp://node01-nfshs107-mail-bf1:/tmp/sp_ssh_algo.conf. err:Executing: program /usr/bin/ssh host XX.XX.XX.XX, user alpha039484, command scp -v -t /tmp/sp_ssh_algo.conf
[kern_servprocd:info:6583] OpenSSH_8.1p1, OpenSSL 1.0.2zd-fips  15 Mar 2022
[kern_servprocd:info:6583] debug1: Reading configuration data /etc/ssh/ssh_config
[kern_servprocd:info:6583] debug1: /etc/ssh/ssh_config line 40: Deprecated option "useroaming"
[kern_servprocd:info:6583] debug2: resolve_canonicalize: hostname XX.XX.XX.XX is address
[kern_servprocd:info:6583] debug2: ssh_connect_direct
[kern_servprocd:info:6583] debug1: Connecting to XX.XX.XX.XX [XX.XX.XX.XX] port 22.
[kern_servprocd:info:6583] debug1: connect to address XX.XX.XX.XX port 22: Operation timed out
[kern_servprocd:info:6583] ssh: connect to host XX.XX.XX.XX port 22: Operation timed out
[kern_servprocd:info:6583] SSH terminating : ssh.c : main : 1412.
[kern_servprocd:info:6583] lost connection
New to NetApp?
  • Was this article helpful?
