SPLinkDownAlert on FAS8200/A300 with SP firmware 5.8
Applies to
- FAS8200
- AFF A300
- Service Processor (SP) firmware version: 5.8
- SP internal switch version:Version16-SB_XXII-ETHSW-RZL
Issue
- System reports SPLinkDownAlert message:
Example:
Mon May 24 05:19:47 CST [Hostname: nphmd: hm.alert.raised:alert]: Alert Id = SPLinkDownAlert , Alerting Resource = SP Config raised by monitor controller
- E0M link up, SP is online while no IP address from sysconfig -a:
Example:
Service Processor Status: Online
Firmware Version: 5.8
Mgmt MAC Address:
Ethernet Link: down, full duplex, auto-neg complete
Using DHCP: no
IPv4 configuration:
IP Address: unknown
Netmask: unknown
Gateway: unknown
IPv6 configuration: Disabled
slot 0: Gigabit Ethernet I210
e0M MAC Address: (auto-1000t-fd-up)
Device Type: 1533
Firmware Version: 3.25-5.5 0x80000674
- SP internal switch version is Version16-SB_XXII-ETHSW-RZL.
Example from "SP-LATEST-CONFIGURATION":
Check revision of programmable devices with revision of images bundled in SP (/usr/local/bin/check_fw_revision.sh)
Versions that do not match will be printed.
Ethernet switch version
Version16 SB_XXII ETHSW RZL
