NetApp Knowledge Base
SAS Shelf ID is not set or is in conflict with an existing shelf
1,220
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
Applies to
SAS shelves
Issue
  • The device ID disk in the SAS shelves is expected to be similar to 2d.10.1 following the standard convention: device_id = Adapter.ShelfID.BayID
  • When reviewing the output of sysconfig -a or sysconfig -r, a long alpha numeric number is in use for the shelf ID instead of the expected number from 0-98.
Example:
Cluster::> system node run -node <node name> -command sysconfig -a
002115F8.21: NETAPP   X343_STBTE1T8A10 NA02 1713.5GB 520B/sect
002115F8.22: NETAPP   X343_STBTE1T8A10 NA02 1713.5GB 520B/sect
002115F8.23: NETAPP   X343_STBTE1T8A10 NA02 1713.5GB 520B/sect
Cluster::> system node run -node <node name> -command sysconfig -r
0c.002115F8.21    0c    10  21  SA:B   0   SAS 10000 1713523/3509295616 1716957/3516328368
0c.002115F8.22    0c    10  22  SA:B   0   SAS 10000 1713523/3509295616 1716957/3516328368
0c.002115F8.23    0c    10  23  SA:B   0   SAS 10000 1713523/3509295616 1716957/3516328368
  • Messages similar to the below may also be observed:
node1 ALERT ses.inconsistent.config: Inconsistent configuration detected for shelf connected to adapter 0b, 0c.
node1 ALERT ses.multipath.ReqError: SAS disk shelf detected without a multipath configuration.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
