SAS Host Adapter with rate unknown for one PHY (remote shelf)
Applies to
- Ontap 9.6P7
- DS2246
- SAS cable X66016A-R6
- FAS8020
- Patch panel configuration.
Issue
- One SAS channel (PHY) has unknown status for remote shelf stack. Example:
slot 0: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C, SAS, <UP>)
Firmware rev: 01.12.09.00
Base WWN: xxxxxxxxxxxxxxx
Phy State: [4] Enabled, 6.0 Gb/s
[5] Enabled, 6.0 Gb/s
[6] Enabled, Rate unknown
[7] Enabled, 6.0 Gb/s
QSFP Vendor: Molex Inc.
QSFP Part Number: 112-00274+A0
QSFP Type: Optical (1490nm DFB) 5m ID:00
QSFP Serial Number: serial_number
