Root migration fails. Node configuration backup fails with Error: mgmtgwd.configbr.backupfailed
Applies to
- ONTAP 9
- NDO Migrate Root
Issue
- The Node configuration backups fail with error, "Failed to open the published package"
Mon Jun 22 04:49:22 -0600 [Cluster1-Node2: mgwd: mgmtgwd.configbr.backupFailed:error]: The node configuration backup Cluster1-Node2.daily.2020-06-22.00_10_00.7z cannot be created. Error: 'Failed to open the published package Cluster1-Node2.daily.2020-06-22.00_10_00.7z at /mroot/etc/cluster_config/pubroot/tmp_pkg-b7cd-05c0-876c-b171.pkg for verification. '.
- During root aggregate migration the process might fail with the below error in
job show
ClusterA::*> job show -id <id> -instance Job ID: <id> Owning Vserver: ClusterA Name: Migrate root aggregate Description: Root aggregate migration job for node ClusterA-01 Priority: High Node: ClusterA-01 Affinity: Cluster Schedule: @now Queue Time: 04/20 16:07:07 Start Time: 04/20 16:07:07 End Time: 04/20 16:22:07 Drop-dead Time: - Restarted?: false State: Failure Status Code: 1 Completion String: Failed to backup node configuration. Reason: Wait Timeout. Job Type: NDO Migrate Root Job Category: Non Disruptive Operation UUID: <uuid> Execution Progress: Complete: Failed to backup node configuration. Reason: Wait Timeout. [1] User Name: admin Process: mgwd
