NetApp Knowledge Base
Power supply firmware cannot be changed
202
Visibility:
Votes:
0
Category:
not set
Specialty:
hw
Last Updated:
Applies to
  • AFF Series
  • FAS Series
  • Replaced Power Supply Unit (PSU)
Issue
storage shelf show shows a different firmware version from the previous one after replacing PSU.
Before Replacement:
Power Supply Units:
                                                     Crest  Power   Reset   PSU              Operational
 ID
Type Part#        Serial#         Power Rating   Factor Drawn   Capable Enabled Firmware Status           PSU Location
  1 7D   114-00148+E0 PSQ09418470XXXX 913            0      0       false   true    0111     normal           rear of the shelf at thebottom left
  2 7D   114-00148+E0 PSQ09418470XXXX 913            0      0       false   true   0111     off              rear of the shelf at the bottom right
After Replacement:
Power Supply Units:
                                                     Crest  Power   Reset
PSU              Operational
 ID Type Part#        Serial#         Power Rating   Factor Drawn   Capable Enabled Firmware Status       PSU Location
  1 7D   114-00148+E0 PSQ09418470XXXX 913            0      0       false   true    0111     normal   rear of the shelf at the bottom left
  2 98   114-00148+F1 PSQ09418470XXXX 913            0      0       false   true  0110     normal   rear of the shelf at the bottom right
New to NetApp?
