NetApp Knowledge Base
Port down on PCI card XL710
169
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS9000
  • X91440A 2-port network adapter
Issue
  • 40G link in X91440A 2-port 40G NIC is down:
cluster::> run -node [node_name] -command sysconfig -a
sysconfig: slot 5 OK: X91440A: 40G high performance
slot 5: 10/40 Gigabit Ethernet Controller XL710 QSFP+
e5e MAC Address: d0:39:ea:xx:xx:xx (auto-unknown-fd-down)
QSFP Vendor: CISCO-AVAGO
QSFP Part Number: AFBR-79EBPZ-CS2
QSFP Serial Number: serila_number
Device Type: XL710 B1
Firmware Version: fw 5.20 nvm 5.05 etid 80008d4d
Part Number: 111-02590
Hardware Revision: B0
::> run -node [node_name] -command sysconfig -ac
  • No light on the QSFP
  • Patch panel cabling is correct
New to NetApp?
Scan to view the article on your device
