Power supply working fine but reporting NO_PSN_PRESENT_ instead of the serial number
Applies to
- FAS8020
- DS2246
Issue
The power supply is working fine but reports outputs similar to:
::> storage shelf show -shelf-id 11 -stack-id 4 -power
Shelf Name: 4.11
Stack ID: 4
Shelf ID: 11
Shelf UID: 50:0a:09:80:03:78:c1:36
Serial Number: SHFHUXXXX000XXX
Module Type: IOM6
Model: DS2246
Shelf Vendor: NETAPP
Disk Count: 24
Connection Type: SAS
Shelf State: Online
Status: Normal
Power Supply Units:
Crest Power Reset PSU Operational
ID Type Part# Serial# Power Rating Factor Drawn Capable Enabled Firmware Status
1 00 PPP-PPPPP+XX NO_PSN_PRESENT_ - - - false true 0000 normal
2 9C 114-00065+B0 PSD041150272769 - - -false true 020F normal
Voltage Sensors:
Voltage Operational
ID (V) Status
1 - not-installed
2 - not-installed
3 5.70 normal
4 12.300 normal
Current Sensors:
Current Operational
ID (mA) Status
1 - not-installed
2 - not-installed
3 10890 normal
4 17610 normal
Errors:
