NetApp Knowledge Base
Optimized takeover of partner aborted, could not disable BDFU
268
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS
  • ONTAP 9
Issue
  • Unable to takeover partner with storage failover takeover or as part of automated nondisruptive upgrade (ANDU).
  • Takeover command succeeds but takeover ultimately fails; output of storage failover show-takeover:
Node       Node Status           Aggregate      Takeover Status
node01     Optimized takeover
           of partner aborted.
           Run the command
           "storage failover
           show-takeover -node
           node02" to display
           the relocation
           status of the
           the partner.             -                -
node02     Optimized takeover
           by partner aborted.
                                 SFO aggregates Failed, could not disable
                                                background disk firmware
                                                updates (BDFU) on node01.
                                                Wait a few minutes then try
                                                the operation again.
                                 CFO aggregates Not attempted yet.
  • There is a disk that remains offline after being upgraded by BDFU (no notification it came back online):
[?] Mon Feb 10 12:01:18 CET [node01: bg_disk_fw_update_a: bdfu.selected:info]: Disk 0a.10.5 [NETAPP X423_TA14E900A10 NA01] S/N [A1B2C34DE5FG] selected for background disk firmware update.
[?] Mon Feb 10 12:01:18 CET [node01: config_thread: raid.disk.assign.offline_ref:notice]: aggregate /aggr1/plex0/rg1/3a.12.11 assigned as an offline reference storage for /aggr1/plex0/rg1/0a.10.5.
[?] Mon Feb 10 12:01:18 CET [node01: config_thread: raid.disk.assign.offline_ref:notice]: aggregate /aggr1/plex0/rg1/3c.20.0 assigned as an offline reference storage for /aggr1/plex0/rg1/0a.10.5.
[?] Mon Feb 10 12:01:31 CET [node01: dyn_dev_qual_admin: dfu.fwDownloaded:notice]: Firmware downloaded to Disk 0a.10.5 [NETAPP   X423_TA14E900A10 NA02] S/N [A1B2C34DE5FG] successfully.
  • Disk reports offline in SYSCONFIG-R (node run -node <node> sysconfig -r):
  RAID Disk    Device      HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
  data        0a.10.5     0a    10  5   SA:A   0   SAS 10000 857000/1755136000 858483/1758174768 (offline)
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • Was this article helpful?
