NetApp Knowledge Base
One node does not send SNMP traps
669
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9.8
  • SNMP trap
Issue
  • SNMP traps are not reaching the trap host destination from one of the cluster nodes.
  • Ping is alive from node management LIF to the trap host destination.
Example:
::> network ping -lif node01_mgmt -vserver cluster1 -destination 172.19.XX.XXX
172.19.XX.XXX is alive
  • Events are generated in the controller.
Example:
::> event generate -node node02 -message-name callhome.dsk.fault -values test
::> event generate -node node01 -message-name callhome.dsk.fault -values test
::> event notification history show -destination snmp-traphost
Time                Node             Severity      Event
9/20/2021 13:35:58  node01           ERROR         callhome.dsk.fault: Call home for test
9/20/2021 13:35:43  node02           ERROR         callhome.dsk.fault: Call home for test
  • Two separate cluster-management LIFs exist on the problematic node, and they are using two different gateways/network routes.
Example:
::> network interface show
            Logical    Status     Network            Current       Current Is
Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
cluster1
            cluster_mgmt2
                       up/up      172.31.XX.XX/24    node01     a0a-3150   true
            cluster_mgmt1
                       up/up      172.17.XXX.XXX/24  node01        e0M     true
            node01_mgmt
            node02_mgmt
                       up/up      172.17.XXX.XXX/24  node02        e0M     true
::> net route show
  (network route show)
Server              Destination     Gateway         Metric
cluster1
                    0.0.0.0/0       172.17.XXX.1     20
                    0.0.0.0/0       172.31.XX.1      20
  • Network traceroute shows No route to host from the problematic node to SNMP trap host destination.
Example:
From the problematic node:
::> network traceroute -node node01 -destination 172.19.XX.XXX
traceroute to 172.19.XX.XXX (172.19.XXX.XXX), 64 hops max, 40 byte packets
 1  * * *
 2  *traceroute: sendto: No route to host
 *traceroute: wrote 172.19.XX.XXX 20 chars, ret=-1
 3 traceroute: wrote 172.19.XX.XXX 20 chars, ret=-1
From the normal node:
::> network traceroute -node node02 -destination 172.19.XX.XXXtraceroute to 172.19.XX.XXX (172.19.XX.XXX), 64 hops max, 40 byte packets
 1  172.17.XXX.1 (172.17.XXX.1)  0.571 ms  0.446 ms  0.285 ms
 2  172.17.XXX.1 (172.17.XXX.1)  0.718 ms  0.991 ms  0.447 ms
 3  172.19.XX.XXX (172.19.XX.XXX)  0.119 ms  0.163 ms  0.125 ms
New to NetApp?
