Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
ONTAP unable to serve iSCSI or Fibre Channel (FC) data from one node with FabricPool
367
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9
  • Fabric Pool
Issue
  • An ONTAP node that owns an aggregate using fabric pool and the hosts see the LUNs but are unable to access the data.
  • Host logs show a medium error
In this example VMware vmkernel logs show a medium error when trying to access a LUN.
2020-01-01T01:10:00.454Z cpu42:2503487)lpfc: lpfc_handle_status:5226: 0:(0):3271: FCP cmd x28 failed <19/179> sid x49ce09, did x499584, oxid x1657 iotag x195d SCSI Chk Cond - Medium Err: Data(x2:x3:x11:xc)
  • In diagnostic privelege on the cluster shell run 'event log show -messagename object.store.*'
If ONTAP shows the node owning the aggregate such as below, the issue is ObjectStore connectivity related.
Tue Jan 01 01:10:01 MDT [NetApp1-01: OscLowPriThreadPool: object.store.unavailable:EMERGENCY]: Unable to connect to the object store "NetApp1_objectstore1" from node 0900000-7000-100a-8cf5-d039ea1abe22.
New to NetApp?
Scan to view the article on your device
