Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
Node reporting "Periodic check of RAID Disk...has failed. The system will correct the problem." every 4 hours
244
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS, AFF
  • Cluster data ONTAP 8.1 to 8.3
  • ONTAP 9.0 and higher
Issue
A node reports the following message for a disk every 4 hours:
Fri Sep 11 04:00:03 -0400 [nodename: statd: monitor.diskLabelCheckFailed:notice]:Periodic check of RAID Disk 0d.23.56 Shelf 23 Drawer 5 Slot 8 Bay 56 [NETAPP   X377_HLBRE10TA07 NA01] S/N [xxxxxxxx] UID [5000CCA2:73B5A2B8:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000] has failed. The system will correct the problem.
New to NetApp?
Scan to view the article on your device
