Node powered off with errors monitor.shutdown.chassisOverTemp:critical "Chassis temperature is too hot: System will be shutdown in 2 minutes"
Applies to
- AFF
- FAS
Issue
- FAS node is powered off.
- Errors observed prior to shutdown via AutoSupport can include:
SHELF OVER TEMPERATURE
CHASSIS OVER TEMPERATURE
CHASSIS OVER TEMPERATURE SHUTDOWN
- Errors observed prior to shutdown in EMS logs can include errors similar to the following:
[FAS-01: dsa_worker3: callhome.shlf.overtemp:error]: Call home for SHELF OVER TEMPERATURE 43 C (109 F)
[FAS-01: dsa_worker3: ses.status.temperatureError:critical]: DS4246 (S/N SHJMS000000011A) shelf 0 on channel 0a temperature error for Temperature sensor 1: critical status; overtemperature failure. Current temperature: 43 C (109 F). This module is on the front of the shelf on the left, on the OPS panel.
[FAS-01: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: In Flow Temp is warning high (53 C).
[FAS-01: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
[FAS-01: dsa_worker4: ses.status.temperatureWarning:warning]: DS4246 (S/N SHJMS000000011A) shelf 0 on channel 0a temperature warning for Temperature sensor 3: non-critical status; overtemperature warning. Current temperature: 51 C (123 F). This module is on the rear of the shelf on the upper left power supply.
[FAS-01: power_low_monitor: monitor.chassisPower.degraded:warning]: Chassis power is degraded: Power Supply Status Critical.
[FAS-01: power_low_monitor: callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical.
[FAS-01: monitor: monitor.globalStatus.critical:critical]: Power Supply Status Critical. Chassis temperature is too high. Disk shelf fault.
[FAS-01: env_mgr: monitor.shutdown.chassisOverTemp:critical]: Chassis temperature is too hot: System will be shutdown in 2 minutes
[FAS-01: env_mgr: callhome.chassis.overtemp:EMERGENCY]: Call home for CHASSIS OVER TEMPERATURE SHUTDOWN
