Node is unresponsive on shutdown due to Service Processor (SP) internal serial port connection
Applies to
- ONTAP 9
- FAS/AFF
- Service Processor (SP)
Issue
- When rebooting a storage controller during ONTAP upgrade or other maintenance, it becomes unresponsive and unreachable in the cluster
- Storage failover states the node is dumping core for many hours
- The SP allows logging in, but shows no prompt to run commands to check state of the node
- The storage controller is inspected physically to find an unknown device plugged into serial console port and after removing this cable, the node becomes responsive again
