Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Node goes down due to environemntal shutdown stating battery not charging even after replacing the NVRAM battery
125
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS
  • AFF
Issue
  • Node suffers an environmental shutdown:
[cluster1-01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL.
[cluster1-01:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery not charging)
  • Node reports the following warning message while booting up:
WARNING:  The battery is experiencing a critical failure:
- Failed to charge the battery
Without a working battery, the system cannot retain data
during a power outage, which can result in data loss.
Power down the system and verify that the battery is
properly installed.
To ignore this failure and boot the system in a mode
where data loss might occur, press 'c' followed by 'Enter'
CAUTION: Using this appliance without NVRAM
battery backup coupled with a power
failure condition CAN CAUSE DATA LOSS.
Are you sure you want to continue (y or n)?
  • SP/BMC firmware is at the latest firmware.
  • NVRAM Battery replacement doesn't help.
New to NetApp?
Scan to view the article on your device
