Newly setup or MB replaced Metrocluster Mediator connection status is false
Applies to
- Ontap 9
- Metrocluster Over IP
Issue
- When checking the status of a newly set up IPmediator the connection status shows as false:
cluster1_node_01::*> metrocluster configuration-settings mediator show
Mediator IP Port
Node Configuration Connection
Status Status
10.234.217.168 31784
cluster1_node_01 true false
cluster1_node_02 true false
cluster2_node_01 true false
cluster2_node_02 true false
