NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
NIC port seeing CRC errors in ifstat
2,509
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS / AFF Systems
  • Networking Adapters
Issue
  • The output of the ifstat command shows high CRC errors on the affected port
::> system node run -node <NODE_NAME> -command ifstat <PORT>
-- interface  e4a  (7 hours, 33 minutes, 13 seconds) --
RECEIVE
 Total frames:    10739k | Frames/second:     395  | Total bytes:     14537m
 Bytes/second:      534k | Total errors:     4921  | Errors/minute:      11
 Total discards:      0  | Discards/minute:     0  | Multi/broadcast:   334k
 Non-primary u/c:     0  | CRC errors:       4921  | Runt frames:         0
 Fragment:            0  | Long frames:         0  | Jabber:              0
  • Following errors are reported in event logs:
[Node-02: vifmgr: vifmgr.cluscheck.crcerrors:alert]: Port e4a on node Node-02 is reporting a high number of observed CRC errors.
New to NetApp?
Scan to view the article on your device
