Multiple disk failures for disks of model X357_TPM5V3T8ATE
Applies to
- ONTAP 9
- X357_TPM5V3T8ATE
Issue
Multiple disk failures:
Fri Jun 25 20:40:37 MSK [node_name: scsi_cmdblk_strthr_admin: scsi.debug:debug]: shm_setup_for_failure disk 0d.11.19 (S/N 39K0A0Z6TRXF) error 80000000h
Fri Jun 25 20:40:37 MSK [node_name: sanown_io: diskown.errorDuringIO:error]: error 20 (disk operation timed out) on disk 0a.11.19 (S/N 39K0A0Z6TRXF) while setting disk reservation
Fri Jun 25 07:51:02 MSK [node_name: disk_server_0: scsi.debug:debug]: shm_setup_for_failure disk 0a.11.15 (S/N 39K0A0ZBTRXF) error 80000000h
Fri Jun 25 07:51:02 MSK [node_name: disk_server_0: scsi.debug:debug]: shm_setup_for_failure disk 0a.11.15 (S/N 39K0A0ZBTRXF) error 40000000h
Fri Jun 25 07:53:32 MSK [node_name: sanown_io: diskown.errorDuringIO:error]: error 13 (fatal disk error) on disk 0a.11.15 (S/N 39K0A0ZBTRXF) while setting disk reservation
Fri Jun 25 12:29:59 MSK [node_name: disk_server_0: scsi.debug:debug]: shm_setup_for_failure disk 0a.11.3 (S/N 39K0A0ZJTRXF) error 40000000h
Fri Jun 25 12:29:59 MSK [node_name: config_thread: raid.config.filesystem.disk.failed:error]: File system Disk /pd01_fas8200_001_1_SSD_1/plex0/rg0/0a.11.3 Shelf 11 Bay 3 [NETAPP X357_TPM5V3T8ATE NA52] S/N [39K0A0ZJTRXF] UID [58CE38EE:2086A318:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000] failed.
Fri Jun 25 22:43:06 MSK [node_name: disk_server_0: scsi.debug:debug]: shm_setup_for_failure disk 0a.11.18 (S/N 39K0A0ZDTRXF) error 40000000h
Fri Jun 25 22:43:06 MSK [node_name: config_thread: raid.config.filesystem.disk.failed:error]: File system Disk /pd01_fas8200_001_1_SSD_1/plex0/rg0/0a.11.18 Shelf 11 Bay 18 [NETAPP X357_TPM5V3T8ATE NA52] S/N [39K0A0ZDTRXF] UID [58CE38EE:2086A304:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000] failed.
Sat Jun 26 03:09:23 MSK [node_name: disk_server_0: scsi.debug:debug]: shm_setup_for_failure disk 0a.11.6 (S/N 39K0A0ZHTRXF) error 40000000h
Sat Jun 26 03:09:23 MSK [node_name: config_thread: raid.config.filesystem.disk.failed:error]: File system Disk /pd01_fas8200_001_1_SSD_1/plex0/rg0/0a.11.6 Shelf 11 Bay 6 [NETAPP X357_TPM5V3T8ATE NA52] S/N [39K0A0ZHTRXF] UID [58CE38EE:2086A314:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000] failed.
