Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
MetroCluster Configure fails due to system ID conflict
191
Visibility:
Votes:
0
Category:
metrocluster
Specialty:
metrocluster
Last Updated:
Applies to
  • MetroCluster Configurations
  • FAS Systems
  • ONTAP 9
Issue
MetroCluster configure will fail noting:
CLUSTER::> metrocluster configure
[Job 259] Configuring Clusters[Job 259] Job failed: Configure command failed on node "NODE-1" in the local
cluster. Reason: (Local node's system id in the nodelist does not match the
NVRAM system id). Check the hardware for errors and make sure all remote nodes
are online, then try the command again with "-refresh true". Use the
"metrocluster operation show" command to view detailed error information.
Resolve the errors, then try the command again.
New to NetApp?
Scan to view the article on your device
