Management port - e0M down
Applies to
- FAS systems
- AFF systems
Issue
- SP Ethernet Link is down in
SYSCONFIG-A
of ASUP.
Service Processor Status: Online
Firmware Version: 5.1P4
Mgmt MAC Address: 00:A0:98:BD:70:10
Ethernet Link: down, 10Mb, half duplex
Using DHCP: no
- Port e0M is also down in
NETWORK-PORTS.XML
of ASUP. - The e0M port which hosts the management LIF is down and the following messages are reported in event logs:
Wed Mar 24 08:40:25 IST [Node-name: mgmt_port_link_status_poll: netif.linkDown:info]: Ethernet e0M: Link down, check cable.
Wed Mar 24 08:40:35 IST [Node-name: vifmgr: vifmgr.port.monitor.failed:error]: The "link_flapping" health check for port e0M (node XXXX) has failed. The port is operating in a degraded state.
Wed Mar 24 08:41:05 IST [Node-name: vifmgr: vifmgr.portdown:notice]: A link down event was received on node Node-name, port e0M.
- The issue remains after a cable swap with the one in the partner
- The issue remains when connecting a laptop directly to the port
- The issue remains after a power cycling service processor (SP)
