Login failed to cluster switch "switch name". Cannot collect tech-support logs
Applies to
- ONTAP 9.5 and later
- Cisco
Issue
- System health alert reporting the below alert:
cluster::> system health alert show
Node: node-08
Resource: switch_name1(FXXXXXXX1234)
Severity: Minor
Indication Time: Fri Nov 11 03:29:34 2022
Suppress: false
Acknowledge: false
Probable Cause: Login failed to Ethernet switch "switch_name1(FXXXXXXX1234)". Cannot collect tech-support logs.
Possible Effect: Ethernet switch tech-support logs are not available in
AutoSupport(R) messages for troubleshooting.
Corrective Actions: 1) To set up public SSH key authentication on the Ethernet switch,
run the "system switch ethernet log setup-password" command.
ONTAP(R) software requires one-time use of the Ethernet switch's administrative login credentials
to set up the public SSH key for ONTAP access.
The administrative credentials will be discarded after the setup command is complete.
2) If public SSH key authentication is already configured, log in to the Ethernet switch
with administrative credentials from an SSH host or serial console to investigate the login failures.
3) To disable tech-support log collection, run the
"system switch ethernet log disable-collection"
command.
- Switch health is degraded due to the alert:
cluster::> system health subsystem show
Subsystem Health
SAS-connect ok
Environment ok
Memory ok
Service-Processor ok
Switch-Health degraded
CIFS-NDO ok
Motherboard ok
IO ok
MetroCluster ok
MetroCluster_Node ok
FHM-Switch ok
FHM-Bridge ok
SAS-connect_Cluster ok
