NetApp Knowledge Base
Logical interface creation with service policy default-data-nvme-tcp fails
434
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
core
Last Updated:
Applies to
  • AFF800
  • ONTAP 9.10.1RC1
  • ONTAP 9.10.1X3
Issue
  • Logical interface creation with service policy default-data-nvme-tcp fails.
Cluster1::> network interface create -vserver svm0 -lif lif_svm0_1 -data-protocol nvme-tcp -address xx.xxx.xxx.xxx -netmask xxx.xxx.xxx.xxx -home-node cluster1-01 -home-port port_name -status-admin up -service-policy default-data-nvme-tcp
(network interface create)
Info: create_imp: Failed to create logical interface.
Error: command failed: Cannot create LIF "lif_svm0_1" on Vserver "svm0" with data protocols "-" because this list of data protocols is inconsistent with service policy "default-data-nvme-tcp". Try the command again without specifying a data protocol list and the system will populate this setting automatically based on the specified service policy.
  • Follow the error prompt to remove -data-protocol option from command line allows lif creation.
  • However, subsequent -data-protocol addition is not possible. The option -data-protocol is only available during initial creation.
Cluster1::> network interface create -vserver svm0 -lif lif_svm0_1 -address xx.xxx.xxx.xxx -netmask xxx.xxx.xxx.xxx -home-node cluster1-01 -home-port port_name -status-admin up -service-policy default-data-nvme-tcp
Cluster1::> network interface show -vserver svm0 -lif lif_svm0_1 -instance
 (network interface show)
                               Vserver Name: svm0
                     Logical Interface Name: lif_svm0_1
                             Service Policy: default-data-nvme-tcp
                               Service List: -
                          (DEPRECATED)-Role: data
                              Data Protocol: none
cluster1::> network interface modify -
    -vserver                  -lif
    -service-policy           -address
    -netmask                  -netmask-length
    -subnet-name              -home-node
    -home-port                -status-admin
    -failover-policy          -firewall-policy
    -auto-revert              -dns-zone
    -listen-for-dns-query     -allow-lb-migrate
    -lb-weight                -failover-group
    -comment                  -force-subnet-association
    -is-dns-update-enabled    -rdma-protocols
cluster1::> network interface create -
    -vserver                  -lif
    -service-policy           -data-protocol
    -address                  -netmask
    -netmask-length           -is-vip
    -auto                     -subnet-name
    -home-node                -home-port
    -status-admin             -failover-policy
    -firewall-policy          -auto-revert
    -dns-zone                 -listen-for-dns-query
    -allow-lb-migrate         -lb-weight
    -failover-group           -comment
    -force-subnet-association -is-dns-update-enabled
    -broadcast-domain         -rdma-protocols
New to NetApp?
