NetApp Knowledge Base
Large number of CRC errors occur on cluster ports
766
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS 2750
  • ONTAP 9
Issue
  • CRC error counts 1212 times on e0b port with ifconfig:
-- interface  e0b  (232 days, 2 hours, 21 minutes, 3 seconds) --
RECEIVE
 Total frames:      252m | Frames/second:      13  | Total bytes:     39644m
 Bytes/second:     1977  | Total errors:     1218  | Errors/minute:       0
 Total discards:      0  | Discards/minute:     0  | Multi/broadcast:  1020k
 Non-primary u/c:     0  | CRC errors:       1212  | Runt frames:         0
 Fragment:            0  | Long frames:         0  | Jabber:              3
 Length errors:       3  | No buffer:           0  | Xon:                 0
 Xoff:                0  | Pause:               0  | Jumbo:            1293k
 Noproto:             0  | Error symbol:      236  | Illegal symbol:    199
 Bus overruns:        0  | Queue drops:         0  | LRO segments:      249m
 LRO bytes:       26713m
| LRO6 segments:       0  | LRO6 bytes:          0
 Bad UDP cksum:       0  | Bad UDP6 cksum:      0  | Bad TCP cksum:       0
 Bad TCP6 cksum:      0  | Mcast v6 solicit:    0
TRANSMIT
 Total frames:      561m | Frames/second:      28  | Total bytes: 139g
 Bytes/second:     6980  | Total errors:        0  | Errors/minute:       0
 Total discards:      0  | Queue overflow:      0  | Multi/broadcast:  1031k
 Xon:                 0  | Xoff:                0  | Pause:               0
 Jumbo:            2565k | Cfg Up to Downs:     2  | TSO non-TCP drop:    0
 Split hdr drop:      0  | Timeout:             0  | TSO segments:      402k
 TSO bytes:        4840m | TSO6 segments:       0  | TSO6 bytes:          0
 HW UDP cksums:     154k | HW UDP6 cksums:      0  | HW TCP cksums:     556m
 HW TCP6 cksums:      0  | Mcast v6 solicit:    0
DEVICE
 Mcast addresses:     3  | Rx MBuf Sz:       4096
LINK INFO
 Speed:           10000M | Duplex:            full | Flowcontrol:       none
 Media state:     activ
e | Up to downs: 8
  • EMS error message gives below output continuously every hour:
Tue Dec 01 04:04:26 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 05:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 06:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 07:04:27 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 08:04:28 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
Tue Dec 01 09:04:29 JST [node 2: intr: netif.linkErrors:error]: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
  • Above error message does not stop even after replacing SAS cable between HA partner controller e0b port as an isolation.
k-tenant-str::> event log show
Time                Node Severity      Event
1/5/2021 15:11:21 node 2    ERROR         netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicat
1/5/2021 14:54:52   node 1    EMERGENCY     vifmgr.clus.linkdown: The cluster port e0b on node node 1 has gone down unexpectedly.
1/5/2021 14:54:52   node 2    EMERGENCY     vifmgr.clus.linkdown: The cluster port e0b on node node 2 has gone down unexpectedly.
1/5/2021 14:11:20   node 2    ERROR         netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
1/5/2021 13:11:20   node 2    ERROR netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port, or NIC, or that a cable connector is not fully inserted in a socket. On a 10/100 port, might indicate a duplex mismatch.
1/5/2021 12:11:19   node 2   ERROR         netif.linkErrors: Excessive link errors on network interface e0b. Might indicate a bad cable, switch port,
Press <space> to page down, <return> for next line, or 'q' to quit... q
6 entries were displayed.
  • CRC error count does not increase before and after cable replacement.
  • This device is switchless cluster configuration, target e0b port is a port that directly connects node 1 to node 2 as a cluster LIF ports.
  • There is no difference in ports between each node connected to speed and duplex, and there is no use of transceivers such as SFP.
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
