The NetApp Knowledge Base Site will be down for 60 minutes on August 13, 2022, from 8 PM to 9 PM PT for system maintenance and infrastructure update.
ISL port might be faulty on NX5596
58
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
network
Last Updated:
Applies to
  • ONTAP 9
  • CISCO NX5596 Cluster network switch
  • Supported version of NX-OS and RCF
Issue
system health alert show output with the following errors:
The cable used to connect switch "switch(sn#) /Ethernet1/41" to the ISL port might be faulty. For the port-channel, please check each individual link.
The cable used to connect switch "switch(sn#)/Ethernet1/42" to the ISL port might be faulty. For the port-channel, please check each individual link.
The cable used to connect switch "switch(sn#) /Ethernet1/43" to the ISL port might be faulty. For the port-channel, please check each individual link.
The cable used to connect switch "switch(sn#)/Ethernet1/44" to the ISL port might be faulty. For the port-channel, please check each individual link.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
