NetApp Knowledge Base
How to update an offline NVMe Flash Cache
2,838
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2620
  • FAS2650
  • FAS2720
  • FAS2750
  • FAS8200
  • FAS8300
  • FAS8700
  • The following EMS example messages are shown as a result of a NVMe failure
"Mon June 25 18:05:23 UTC [node01: gemini-notif-thread: callhome.nvme.offline:alert]: Callhome for Flash Cache NVMe Offline."
  • sysconfig -a of the node shows:
1 : Flash Cache NVMe
state: failed
model: X3310A
s/n: 123456789
  • The node shows Multi-Path HA.
  • The Firmware is not updated on both nodes
New to NetApp?
Scan to view the article on your device
