We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
How to troubleshoot correctable memory errors on 62XX, 32XX, 25XX and 22XX-series systems
1,124
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS25XX, FAS22XX, FAS/V32XX, and FAS/V62XX only
  • All versions and modes of ONTAP
NetApp controllers feature error-correcting code (ECC) memory modules (DIMM) for both main memory and the NVRAM subsystem. Correctable memory errors are handled automatically, with no intervention and no impact on system performance. Correctable ECC error messages are located in the system log or EMS event log.
Correctable ECC errors are not an indicator that an uncorrectable ECC error will occur. Uncorrectable memory errors will cause a system disruption (panic). If a system disruption occurs, the panic message will call out the DIMM or DIMMs where the uncorrectable error occurred, those DIMMs should then be replaced.
Check Active IQ if this impacts your systems.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
