Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
How to troubleshoot correctable memory errors
6,130
Visibility:
Votes:
3
Category:
data-ontap-8
Specialty:
hw
Last Updated:
Applies to
  • AFF systems
  • FAS systems
  • V-Series systems
Check Active IQ if this impacts your systems.
NetApp controllers feature error-correcting code (ECC) memory modules (DIMM) for both main memory and the NVRAM subsystem.
  • Correctable memory errors are handled automatically, with no intervention and no impact on system performance.
    • Correctable ECC error messages are located in the system log or EMS event log.
    • Correctable ECC errors are not an indicator that an uncorrectable ECC error will occur.
  • Uncorrectable memory errors will cause a system disruption (panic).
    • If a system disruption occurs, the panic message will call out the DIMM or DIMMs where the uncorrectable error occurred, those DIMMs should then be replaced.
New to NetApp?
Scan to view the article on your device
