NetApp Knowledgebase
How to reinstall a system with Advanced Drive Partition version 2 (ADPv2)
1,007
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  •    All Flash FAS
  •    ONTAP 9.2
This  KB article describes the guidance how to partition SSD drives when you have the half-populated shelf.
In some situation when you have the system either with internal or external SSD shelf which is half-populated (24 bays shelf with only 12 drives installed), you might not be able to finish the procedure explained in the KB How to configure Advanced Drive Partitioning using ONTAP Boot Menu Option 9
The reason for this is the conflict with the half-shelf policy where the ONTAP expects 24 disks assigned half-half to the HA pair. You can recognize this if console logs, after selecting menu option 9b  to view the following:
### Console logs ###
AutoPartAFFDetermination: total_disks: 12 num_internal_disks: 0 num_ssds: 12 num_unknowns: 0 num_mediator_disks: 0 num_not_supported: 0 all_ssd? true
AutoPartDiskScan: CandidateDisks: 12 UsableDisks: 12 LocalDisks: 0 UnusableSSDs: 0 PartitionMethod: Root+Data1+Data2
AutoPartDistributionCheck: LocalExpected: 6 PartnerExpected: 6 CandidateDisks: 12 LocalAssigned: 0 NotYetAssigned: 12
AutoPartRootConfig: root d+p+s=3+2+1, root aggr size=112958795 (blks) per 3 disks, root partition size=37660227 (blks)
AutoPartRequestedDiskAssignment: DiskMaxCount: 12 CksumType: block Pool: 0 RPM: 50000 DiskType: SSD
AutoPartInfo: Disks may be from internal or external shelf
9b
AdpInit: Root will be created with 6 disks with configuration as (3d+2p+1s) using disks of type (SSD).
bootarg.bootmenu.selection is |4|
AdpInit: System will now perform initialization using option 4
BOOTMGR: The system has 0 disks assigned whereas it needs 6 to boot, will try to assign the required number.
sanown_assign_X_disks: init boot assign with half shelf policy
Jun 01 11:27:07 [localhost:diskown.hlfShlf.assignStatus:notice]: Half shelf based automatic disk assignment is "enabled".
sanown_split_shelf_resv_lock_disk: msg success op: RESERVE lock disk:  status: 0
sanown_split_shelf_resv_lock_disk: msg success op: RELEASE lock disk:  status: 0
BOOTMGR: already_assigned=0, min_to_boot=6, num_assigned=0
BOOTMGR: Assigned 0 out of 6 disks requested
fm_run0: no local disks found & OFW channel is not up.
Jun 01 11:27:27 [localhost:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
Terminated
Uptime: 2m12s
System halting...
### EOL ###
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
