NetApp Knowledge Base
How to read IFSTAT counters on your AFF/FAS systems
1,138
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • Clustered Data ONTAP 8
  • Data ONTAP 7-mode
  • This article provides reference for counters seen in the IFSTAT output
Data ONTAP 7-mode
node> ifstat -a
Clustered Data ONTAP 8 and ONTAP 9
The command is executed from the Nodeshell of each node
cluster::> system node run -node fas2220-rtp-1a -command ifstat -a
Output example
-- interface  e0a  (6 days, 19 hours, 46 minutes, 1 second) --
RECEIVE
 Frames/second:       6  | Bytes/second:      551  | Errors/minute:       0
 Discards/minute:     0  | Total frames:      249k | Total bytes:     19489k
 Total errors:        0  | Total discards:      0  | Multi/broadcast:   235k
 No buffers:          0  | Non-primary u/c:     0  | L2 terminate:        0
 Tag drop:            0  | Vlan tag drop:       0  | Vlan untag drop:     0
 Vlan forwards:       0  | Vlan broadcasts:     0  | Vlan unicasts:       0
 CRC errors:          0  | Alignment errors:    0  | Runt frames:         0
 Long frames:         0  | Fragment:            0  | Jabber:              0
 Xon:                 0  | Xoff:                0  | Ring full:           0
 Jumbo:               0  | Jumbo error:         0  | Index error:         0
 Force wakeup:        0
TRANSMIT
 Frames/second:       4  | Bytes/second:      659  | Errors/minute:       0
 Discards/minute:     0  | Total frames:    26386  | Total bytes:      2443k
 Total errors:        0  | Total discards:      0  | Multi/broadcast: 11256
 Queue overflows:     0  | No buffers:          0  | Single collision:    0
 Multi collisions:    0  | Late collisions:     0  | Max collisions:      0
 Deferred:            0  | Xon:                 0  | Xoff:                0
 MAC Internal:        0  | Jumbo:               0
LINK_INFO
 Current state:       up | Up to downs:         0  | Speed:            1000m
 Duplex:            full | Flowcontrol:       full
-- interface  e0b  (6 days, 19 hours, 46 minutes, 1 second) --
RECEIVE
 Frames/second:       0  | Bytes/second:        0  | Errors/minute:       0
 Discards/minute:     0  | Total frames:        0  | Total bytes:         0
 Total errors:        0  | Total discards:      0  | Multi/broadcast:     0
 Force wakeup:        0
TRANSMIT
LINK_INFO
 Current state:     down | Up to downs:         1  | Speed:           10000k
 Duplex:            full | Flowcontrol:       none
-- interface  e0M  (4 days, 8 hours, 11 minutes, 18 seconds) --
RECEIVE
 Total frames:      370k | Frames/second:       1  | Total bytes:     37682k
 Bytes/second:      100  | Total errors:        0  | Errors/minute:       0
 Total discards:      0  | Discards/minute:     0  | Multi/broadcast:   199k
 Non-primary u/c:     0  | CRC errors:          0  | Runt frames:         0
 Fragment:            0  | Long frames:         0  | Jabber:              0
 Length errors:       0  | Alignment errors:    0  | No buffer:           0
 Xon:                 0  | Xoff:                0  | Pause:               0
 Jumbo:               0  | Noproto:             0  | Error symbol:        0
 Illegal symbol:      0  | Bus overruns:        0  | Queue drops:         0
 LRO segments:        0  | LRO bytes:           0  | LRO6 segments:       0
 LRO6 bytes:          0  | Bad UDP cksum:       0  | Bad UDP6 cksum:      0
 Bad TCP cksum:       0  | Bad TCP6 cksum:      0  | Mcast v6 solicit:  947
TRANSMIT
 Total frames:      168k | Frames/second:       0  | Total bytes:     24528k
 Bytes/second:       65  | Total errors:        0  | Errors/minute:       0
 Total discards:      0  | Queue overflow:      0  | Multi/broadcast:     0
 Max collisions:      0  | Single collision:    0  | Multi collisions:    0
 Late collisions:     0  | Xon:                 0  | Xoff:                0
 Pause:               0  | Jumbo:               0  | Cfg Up to Downs:     0
 TSO non-TCP drop:    0  | Split hdr drop:      0  | Timeout:             0
 TSO segments:      976  | TSO bytes:        8675k | TSO6 segments:       0
 TSO6 bytes:          0  | HW UDP cksums:    3121  | HW UDP6 cksums:      0
 HW TCP cksums:   16750  | HW TCP6 cksums:      0  | Mcast v6 solicit:    0
DEVICE
 Mcast addresses:     3  | Rx MBuf Sz:       4096
LINK INFO
 Speed:            1000M | Duplex:            full | Flowcontrol:       full
 Media state:     active | Up to downs:          1
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
