Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
How to partition a drive manually in ONTAP 9
8,046
Visibility:
Votes:
2
Category:
disk-drives
Specialty:
hw
Last Updated:
Applies to
  • ADPv1
  • ADPv2
  • ONTAP 9
  • In some scenarios, a particular disk might not be partitioned automatically or is partitioned with a wrong partition size.
  • In this case, it requires manual re-partitioning.
  • However, the target disk must be with the same size and type as the source disks from the aggregate the disk will belong.
  • Partition sizes must not differ from those that the system was initialized with.
New to NetApp?
Scan to view the article on your device
