How to justify volume metadata footprint in ONTAP 9?
Applies to
- ONTAP 9
- Space usage
- Metadata consumption
- Volume size can grow and shrink over time;
- Usage of the volume can significantly change over time based on capacity, file count and others;
- Some metadata reserve or usage associated with volume peak usage (e.g. file count) will never shrink again, despite the volume size is being shrunk;
- While
df
command on Unix andUsed Space
value in Windows Properties tab might account for certain metadata, the Unixdu
command andSize on
Disk
in (Windows) will only account for user data.
