NetApp Knowledgebase
Health monitor alert SPNotConfiguredAlert
456
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS
  • All Flashed FAS (AFF)
Issue
  • AutoSupport (ASUP) reports SPNotConfiguredAlert
  • system health alert show command show SPNotConfiguredAlert
Example:
                      Node: cluster-01
                   Monitor: controller
                  Alert ID: SPNotConfiguredAlert
         Alerting Resource: SP Config
                 Subsystem: Service-Processor
           Indication Time: Wed Apr 24 14:42:27 2019
        Perceived Severity: Major
            Probable Cause: Configuration_error
               Description: Service Processor is not properly configured.
        Corrective Actions: 1. Use the "system service-processor network modify" command to configure the network interface                             of the Service Processor.
                            2. Use the "system service-processor image modify -node cluster-01 -autoupdate true" to                             configure AutoUpdate feature of the Service Processor.
                            3. Contact the technical support if the alert persists.
           Possible Effect: You might not be able to use the Service Processor to remotely access, monitor, and troubleshoot                             your storage system.
               Acknowledge: false
                  Suppress: false
                    Policy: SPNotConfiguredAlertPolicy
              Acknowledger: -
                Suppressor: -
    Additional Information: Status: online
                            Configured: false
                            Firmware Version: 5.5P1
                            Booted Version :  primary
                            Public Link Status:  down
                            Warning Count: 7
                            Link Warning Count: 8
    Alerting Resource Name: SP Config
     Additional Alert Tags: device
                      Node: cluster-02
                   Monitor: controller
           Indication Time: Wed Apr 24 14:49:17 2019
                            2. Use the "system service-processor image modify -node cluster-02 -autoupdate true" to                             configure AutoUpdate feature of the Service Processor.
               Acknowledge: false
                  Suppress: false
              Acknowledger: -
                Suppressor: -
                            Configured: false
                            Warning Count: 9
                            Link Warning Count: 10
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
