HDDs are failed unsupported in a FAS system
Applies to
- FAS system
- AFF system
Issue
HDDs installed in a FAS or AFF system are failed unsupported and report the following errors.
cluster::> storage disk error show
Disk Error Type Error Text
1.20.0 notallflashdisk The node is configured with All-Flash Optimized personality and this disk is not an SSD. The disk needs to be removed from the system.
1.20.1 notallflashdisk The node is configured with All-Flash Optimized personality and this disk is not an SSD. The disk needs to be removed from the system.
1.20.2 notallflashdisk The node is configured with All-Flash Optimized personality and this disk is not an SSD. The disk needs to be removed from the system.
