Green LED does not light up after disk replacement on NS224 shelf
Applies to
- ONTAP 9
- NS224 Shelf running the latest firmware
Issue
- After replacing a disk in an NS224 shelf, the drive LED does not light up green.
- The replaced disk is missing from both nodes:
::> system node run -node <node> -command sysconfig -a
10.1.14: NETAPP X4013S17337T6NTE NA53 7325.4GB 4160B/sect (S60RNA0R900335)
10.1.15: NETAPP X4013S17337T6NTE NA53 7325.4GB 4160B/sect (S60RNA0R900328)
10.1.17: NETAPP X4013S17337T6NTE NA53 7325.4GB 4160B/sect (S60RNA0R900336) <<<<<<< Drive in slot 16 is missing
10.1.18: NETAPP X4013S17337T6NTE NA53 7325.4GB 4160B/sect (S60RNA0R900694)
- The disk is missing even after multiple reseat attempts.
