NetApp Knowledge Base
Flash Cache is stuck in rewarming phase and does not accept insertions
534
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9.3P8 and earlier releases
Issue
Flash Cache is stuck in rewarming phase and does not accept insertions with the following symptoms:
  • High latency from Disk layer
  • High Disk utilization
  • Low cache insert/hit rate in Flash Cache
To confirm the low cache insert/hit rate in Flash Cache:
Example:
cluster::> set advanced
Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel.
Do you want to continue? {y|n}: y
cluster::*> statistics start -sample-id <test1> -object ext_cache_obj -counter inserts|hit_percent|rewarm_aggrs_failed
Statistics collection is being started for sample-id: test1
fas8200-2n-dal-1::*> statistics stop -sample-id <test1>
Statistics collection is being stopped for sample-id: test1
fas8200-2n-dal-1::*> statistics show -sample-id <test1>
Object: ext_cache_obj
Instance: ec0
Start-time: 5/18/2021 10:43:17
End-time: 5/18/2021 10:43:25
Elapsed-time: 8s
Scope: cluster-1a
    Counter                                                     Value
    hit_percent                                                    0%
    inserts                                                         0
Instance: ec0
Elapsed-time: 8s
Scope: cluster-1b
    Counter                                                     Value
    hit_percent                                                    0%
    inserts                                                         0
4 entries were displayed.
Notes:
  • hit_percent should be 0%, indicating no cache hits
  • inserts should be lower than 10/s, indicating no data is being inserted into Flash Cache
New to NetApp?
